kkothamasu
Dec 22, 2018Aspirant
Raidar 6.4.0 not locating NAS
I have my Readynas 104 connected to my network but Raidar doesn't seem to be able to locate it, I get the following message: "RAIDar could not find any NETGEAR storage on your network. Check that you...
Jan 12, 2019Guru - Experienced User
JBDragon1 wrote:
What I would do is log into my Router and locate your NAS that way.
Yes, and it's useful to reserve an IP address for the NAS there. That's better than assigning static addresses (which are assigned in the client devices, not the router) - since it allows you to more easily manage your addresses, and eliminates the risk of losing connectivity when you upgrade routers.
That said, it's worth taking the time to get RAIDar to function. It does have some diagnostic functions that can help when the NAS admin interface fails.
kkothamasu
Jan 12, 2019Aspirant
Thank you, to both of your points I've been letting the router assign the IP for years and from time to time when we have long power outages I've noticed the IP address for the NAS gets reset and I'm having to find what it is everytime.
