Pete10p's avatar
Pete10p
Raidar has stopped seeing ReadyNas
I have had Raidar 6.5 running on my Winows 10 PC but suddenly its stopped finding my ReadyNas units. The units are there and working fine and accessable from my browser but nothing now shows on Raidar.
Any suggestions?
  • JohnCM_S's avatar
    JohnCM_S
    NETGEAR Employee Retired
    Hi Pete10p,
    Do you have any security software installed on the Win10 PC? You can try disabling that and see if RAIDar can detect the NAS.
    You can also try it on a different PC and see if you will still have the same issue.
    • Pete10p's avatar
      Pete10p
      Thanks for the response.
      I tried that with no change.
      From my browser I rebooted both ReadyNas's and Raidar can see them. I'm not sure why that fixed the problem but so far all is OK.
ProSupport for Business
