TheWarTurtle
Jan 03, 2024Aspirant
RaidX Recovery RN31400
Several years ago I made a a blunder and removed a drive when I shouldn't have. Basically I inserted a new drive for the array to be rebuilt and subsequently pulled it before it finished. The system ...
Jan 03, 2024Guru - Experienced User
TheWarTurtle wrote:
Several years ago I made a a blunder and removed a drive when I shouldn't have. Basically I inserted a new drive for the array to be rebuilt and subsequently pulled it before it finished. The system then told me the volume was inactive on 3 of the 4 drives with the 4th drive showing nothing.
Do you still have all the disks? If so, do you know which are the three original ones and which one was added?
Also, do you still thave the RN314?
TheWarTurtle wrote:
The system then told me the volume was inactive on 3 of the 4 drives with the 4th drive showing nothing. Is there anyway to rebuild and recover the array?
There are two options.
One is to use RAID recovery software that supports BTRFS. ReclaiMe is one package that several have used with success. You'd need a way to connect at least the three original disks to a Windows PC, and you'd need to purchase the recovery software.
The second way is to put the drives back in the NAS (or alternatively in a different linux system that has BTRFS and MDADM installed). In the case of the NAS, you can boot it up in tech support mode. You connect with telnet, and log in as root, using a backdoor password. Either way, you can then attempt to forcibly assemble the RAID array and then remount the data volume.
