jnorback
Nov 27, 2018Aspirant
mount_block_root +267 on RN31400 + failing USB Firmware recovery
I upgraded my RN31400 (S/N 3C38460J0024C) to v6.9.4 last week.
After a shutdown at a later time I ended up with "mount_block_root +267" errors all the time when I try to reboot it.
It was impossible to take it up to any boot menu for memory/disk tests so I followed the only hits on mount_block_root that I coud find: "How-do-I-use-the-USB-Recovery-Tool-on-my-ReadyNAS-OS-6-storage-system".
My USB firmware recovery process with 6.9.4:
I have tried 2 different USB drives of good quality and it seems that my NAS successfully is able to read from the USB drives and it shuts itself down within a few minutes.
The problem now is that it hangs on the reboot after the firmware refresh (which is why I tried 2 different USB drives), the longest time I have left it so far is for one hour on the "Booting ..." screen.
I will source a few more USB drives but I don't have any hope that there will be any other outcome.
I should also mentioned that one of my 4 x 2 TB drives (in slot 2) had started to indicate a few errors but nothing serious. I got a new drive yesterday but I am not certain if I should even consider changing thar disk at this time.
Please advice. I do have backups but none local so it would be rather painfull to recover over the WAN.
jnorback wrote:
I bought it on 2016-10-06 so no free lifetime chat support but I guess I could try to go down the HW replacement path unless you have another suggestion?
It is under warranty, so I agree the RMA path makes sense.
If this happened at shutdown, I don't think a USB recovery would help. So I don't recommend trying that again.
Did you try removing the disks (labeling them by slot), and then boot the system diskless? That should complete quickly, and the NAS should give you a "no disks" status on the LCD. You should also see that in RAIDar. If you get that, it gives you some confidence that the chassis is more-or-less functional.
Note that if your NAS was purchased between 1 June 2014 and 31 May 2016, then you have free lifetime chat support via my.netgear.com. If you have that you should use it. Paid support is also an option.
- jnorbackAspirant
Hi Stephen,
I hadn't tried to remove the drives but I have now and it still hangs on "Booting..." so I guess it is a chassi HW (or potential firmware) issue.
