nulled
Apr 06, 2026Aspirant
Failing ReadyNAS Ultra 4 Plus
I noticed one morning my NAS had powered down and couldn't turn it back on. After turning the power off to it completely and waiting a couple of minutes, it turned back on. Strangely it then turns of...
nulled
Apr 08, 2026Aspirant
Yeah I replied to StephenB but it didn't post for some reason. Anyway thanks for the help. At this stage won't need to use WSL but will keep it in mind if the chassis dies on me in the future.
I've put everything back in but have used a modified standard ATX PSU until a replacement Flex ATX. Going get a Seasonic SS-250SU that's hopefully a bit more solid and modify the pinouts.
Sandshark wrote:make sure you seal the gap where the PC power cord goes in so that the chassis fan works properly to pull air over the drives.
The OEM PSU had a clear plastic thing that sat between the PSU and the chassis, does that do anything meaningful? I currently have everything re-assembled but with the ATX cord sticking out through the cut-out where the PC power cord used to go.
Sandshark
Apr 08, 2026Sensei
That plastic air dam is critical in making sure the airflow gets into the power supply since the original has no PSU fan. So are some of the additional holes in the top cover. Unless you buy a supply that has a fan mounted on the end opposite the power cord socket, you need to do something to make sure there is sufficient PSU airflow. A fan on the other end has nowhere to blow and does nothing. With many, the best thing to do is swap the top cover and air dam with the original and disconnect the fan. Some aluminum tape can be used to keep the air dam in place.
- nulledApr 08, 2026Aspirant
Ok great thanks for the info. The Seasonic has a fan adjacent to the power socket so should be fine. If I disconnect it due to noise etc I'll make sure to have the air dam in place.
- SandsharkApr 09, 2026Sensei
To be useful in a legacy ReadyNAS, the fan must be on the other end. Unless you cut a hole for it, a fan on the power socket end has nowhere to exhaust. One on the other end typically blows in, not out and isn't blocked by the chassis. Even reversing the fan on the power cord end won't help, as it will then have a blocked inlet as well as be fighting the chassis fan.
