reburns
Dec 01, 2020Aspirant
Pro Pioneer Booting stuck at 96% after OS6 upload
Hello - I started with a conversion from Raidiator 4.2.31 to OS6 on an Pro Pioneer and may have misstepped. BTW, everything is backed up twice and I'm planning on the ensuing data wipe. I wa...
- Dec 01, 2020
If you didn't install the Prep add-on before installing the firmware upgrade then it won't automatically do the factory reset. Installing OS6 over the top of RAIDiator-x86 4.2.x will leave the system in a state where it can't complete a normal boot.
Power off and do the manual factory reset using the boot menu. That will wipe the disks and do a clean install of OS6.
mdgm
Dec 01, 2020Virtuoso
