wolfie111
Dec 20, 2021Guide
ReadyNAS Pro 516 No Volume Exists
Hi, Hope someone out there can help. Its been awhile since I needed community support for my unit. When I recently realized the unit could not be accessed, i soft reset and the interface shows "No...
wolfie111
Jan 06, 2022Guide
Thanks @StephenB,
That support link seems to be an incredibly expensive and perhaps risky investment for the average consumer. Is there someway you or someone else on these forums (@rn_enthusiast was mentioned but I havent heard from him) could help out here, at least to understand the problem and perhaps get me started on trying to recover my data? I'm at a complete loss. I had some experience with SSH some several years ago, though I was guided through that. I'm, willing to give it a shot given the alternatives.
rn_enthusiast
Jan 15, 2022Virtuoso
Hi guys
Sorry, was on holidays :D
You wanna throw me the logs wolfie111 ? I can take a look at them for you.
When you access the NAS Admin web page, go to: System > Logs and here you will see a button called "Download Logs" on the right-hand side. Click this and it will download a zip file with all the NAS logs inside.
Take this zip file and upload to your Dropbox, Google Drive or similar and then make a link where I can download the log zip file. PM me this link please. Then I will have a look to see what is going on.
Cheers
- wolfie111Apr 21, 2022Guide
- rn_enthusiastApr 26, 2022Virtuoso
Hi wolfie111
Your md127 data raid seems to start fine here.
[Thu Apr 21 13:14:22 2022] md/raid:md127: raid level 5 active with 3 out of 3 devices, algorithm 2 [Thu Apr 21 13:14:22 2022] RAID conf printout: [Thu Apr 21 13:14:22 2022] --- level:5 rd:3 wd:3 [Thu Apr 21 13:14:22 2022] disk 0, o:1, dev:sda4 [Thu Apr 21 13:14:22 2022] disk 1, o:1, dev:sdb4 [Thu Apr 21 13:14:22 2022] disk 2, o:1, dev:sdc4 [Thu Apr 21 13:14:22 2022] md127: detected capacity change from 0 to 4000511819776 [Thu Apr 21 13:14:23 2022] BTRFS: device label 7c6e20ee:data devid 2 transid 797642 /dev/md127But the filesystem complains that it cannot read the array.
[Thu Apr 21 13:14:24 2022] BTRFS error (device md127): failed to read the system array: -5 [Thu Apr 21 13:14:24 2022] BTRFS error (device md127): open_ctree failedAnd the BTRFS log shows that there is a missing raid, beyond md127.
Label: '7c6e20ee:data' uuid: d46a0c6b-9371-4694-8dda-ed1fc2ee239b Total devices 2 FS bytes used 2.41TiB devid 2 size 3.64TiB used 414.03GiB path /dev/md127 *** Some devices missing
Looking at the partition table, I see the disks are partitioned into dual partitions of 2TB each (partitions 3 and 4 on each disk).8 0 3907018584 sda 8 1 4194304 sda1 8 2 524288 sda2 8 3 1948793912 sda3 <<<<==== 8 4 1953506020 sda4 <<<<==== 8 16 3907018584 sdb 8 17 4194304 sdb1 8 18 524288 sdb2 8 19 1948793912 sdb3 <<<<==== 8 20 1953506020 sdb4 <<<<==== 8 32 3907018584 sdc 8 33 4194304 sdc1 8 34 524288 sdc2 8 35 1948793912 sdc3 <<<<==== 8 36 1953506020 sdc4 <<<<==== 9 0 4192192 md0 9 1 523264 md1 9 127 3906749824 md127That would mean the NAS normally assembles md127 and md126, and the BTRFS filesystem can stick these two raid instances together into one data volume. But I don't see any attempt from the NAS to assemble md126 as one would expected given how the disks are partitioned. But it explains why the BTRFS logs are complaining about a missing raid device.
I don't have a good explanation as to why the NAS isn't attempting to assemble the missing raid. In a case like this, one should examine the raid super blocks to determine what is going on with missing raid. It requires some expertise and Netgear Level 3 support should look at this, realistically. If the data matters, I would suggest to contact then regarding a data recovery contract. It is not easily fixed on your own and certainly goes beyond forum based assistance.
https://kb.netgear.com/69/ReadyNAS-Data-Recovery-Diagnostics-Scope-of-Service
Cheers
