villa1
Dec 18, 2014Tutor
READYNAS Ultra 2 looses network connectivity
Hi, Im having an issue with the network connection of my ReadyNas DUO Ultra 2. When I start copying files into the NAS device, it looses network connectivity and it disappear from network. Neith...
Nhellie
Dec 18, 2014Virtuoso
villa wrote: Hi Nhellie,
thanks for you information, very useful.
I don't understand from this page... the replacement for my x86 model (RND2000) is an ARM model (RN10200). In case I have to replace it, I would like it was a x86 model too.
The point is :) I just want the replacement for the Ethernet dual port, either through a new support I would be in a position to adquire or buying directly to them the replacement part. My end of warranty was last 23 Nov 2014, Is not a matter I'm trying to get it by free :lol: I want to pay :o
Yours is an RNDU2000 and the direct replacement is RN31200, (but it does not mean that this is the only unit your can use).
Ha, I see but as far as I know Netgear does not sell parts only, probably you might need to replace the entire chassis so I agree with vandermerwe, might as well just get a new NAS.
