GaretMD
Sep 21, 2023Follower
Removing ReadyCloud/ ReadyNas users post April 2023
Hi I still have a couple of ReadyCloud users on my ReadyNas RN104. How do I remove them so there are only local users? The readynas is running Firmware version 6.10.9 And is in all other w...
AnishaA
Oct 08, 2023NETGEAR Employee Retired
Hello GaretMD
And welcome to the NETGEAR Community! 🙂
ReadyCLOUD is officially terminated, and no longer will be available at service or support.
Performing a Factory reset may erase all the data. If you are concerned about the data you can backup all the data and perform a factory reset. But that would be complex.
It is possible to remove the user from the ReadyCLoud account from the GUI. Since it is terminated, it would not much possible to remove the user from the account.
Have a lovely day,
Anisha A
Netgear Team
