Kardano
Apr 03, 2017Luminary
RN214 - No PHP and PHP apps on FW 6.7.0
After update FW to 6.7.0 (from 6.6.1) no PHP apps works. And no Web interface.
I Tried Reinstall OS - not hepling.
I Tried Factory default. (Twice) and config NAS.
Web interface is OK. after i...
- Jun 22, 2017
I installed the final firmware release and the problem seems to be solved.
Thank you!
mdgm-ntgr
Jun 15, 2017NETGEAR Employee Retired
ReadyNASOS 6.7.5-RC1 is now available!
You can try this if you like or wait for the production release.
Heino
Jun 22, 2017Guide
Thank you!
