a20rju's avatar
a20rju
Re-use old REadyNAs HDD's
Hi, I got a 1TB drive that was in use on my old ReadyNAS Duo (RND2000 V2). Deciding that it is more useful in a PC, I've  connected it internally to a newly built Windows 10 PC. But, It shows up in Disk management as being only 30mb in total capacity..!
Anyone have any ideas what could have happened to the rest of the storage and if I can get it back?
The recovery of the data isn't important....
Cheers in advance..,
    • StephenBThis is the procedure I always use to recycle my HDD to be reused on ReadyNas devices but Windows reformat stuff is suficient.
      • StephenB's avatar
        aalexandrebeta wrote:
        StephenB This is the procedure I always use to recycle my HDD to be reused on ReadyNas devices but Windows reformat stuff is suficient.
        OS 6 NAS won't add a formatted drive to the RAID array w/o confimation.  They will add unformatted drives immediately (which sometimes is a bit simpler).
        One way to unformat a drive is to use the quick zeros write test in Lifeguard.  Another is to delete each "volume" on the disk with the windows disk manager (which deletes the partitions).
  • StephenB's avatar
    Usually Disk Manager shows the full capacity with a few partitions.  Though Windows doesn't support the file system, so they aren't mounted.
    Try running vendor diags (WDC Lifeguard or Seagate Seatools for instance).  If the diags pass, you can try zeroing the drive (both have destructive write-zero tests).  Then look again at disk manager.
ProSupport for Business
