Dewdman42
Aug 26, 2025Virtuoso
Which backup method?
So there are two primary backup methods provided in frontview, for purpose of backing up my volume data. There is the so called "File Backup" and there is ReadyDR. I'm assuming my machine (524x) su...
Sep 04, 2025Guru - Experienced User
Dewdman42 wrote:I assume you mean check the box that says only create automatic snapshots if there are actual changes
yes
Dewdman42 wrote:I should have brought this ultra2plus back into action a long time ago, actually I'm impressed at how well it runs basic stuff, no plex or anything, but its handing iSCSI and rsync like a champ
If I recall correctly, the Ultra 2 Plus hardware is the same as the Pro 2. Fast enough to saturate a gigabit ethernet connection for basic storage. My Pro 6 is still in service as part of my own backup plan.
Sandshark
Sep 07, 2025Sensei - Experienced User
StephenB wrote:If I recall correctly, the Ultra 2 Plus hardware is the same as the Pro 2.
It is. With OS4.2.x, certain functions (like Active Directory integration) were disabled if the vpd file identified the NAS as an "Ultra" or "Ultra Plus" rather than a "Pro" unit. With OS6, an Ultra2 Plus is functionally identical to a Pro2. The Ultra2 (non-plus) has a CPU with fewer cores but also no longer has functions disabled when running OS6.
