Feb 18, 2022Guru - Experienced User
Workaround for ERR_SSL_VERSION_OR_CIPHER_MISMATCH problem for Sparc NAS (4.1.x firmware)
This workaround eliminates the redirection of http://nas-name-or-ip/admin to https://nas-name-or-ip/admin for NAS running 4.1.x firmware. It does require ssh to install.
Entering https://nas-na...
sonvolt99
May 02, 2022Star
Hi Stephen,
Its a NAS Duo V1 running the 4.1.17 mod https://community.netgear.com/t5/forums/replypage/board-id/readynas-general/message-id/47827
, which I use to backup my Unraid self built NAS. I edited virtual.conf (both) the one in etc/frontview/apache
and one in etc/default/etc/frontview/apache.
The change worked as I no longer get the error ssl msg and got the correct response when I restarted frontview.
Since I only use it as a backup it's not a bit deal as I power it on once a week run a RSYNC from my Unraid server then
power off backup NAS with a curl script. I've tried chrome/edge & firefox all the same this site can't be reached refused to connect.
Cheers
Ken
SamirD
May 02, 2022Prodigy
The easiest solution I've found for accessing older browser based devices is to simply use a portable version of the older browser it requires. Firefox 52 ESR 32-bit has done well for me for all these including both my Netgear NAS units.
