Feb 18, 2022Guru - Experienced User
Workaround for ERR_SSL_VERSION_OR_CIPHER_MISMATCH problem for Sparc NAS (4.1.x firmware)
This workaround eliminates the redirection of http://nas-name-or-ip/admin to https://nas-name-or-ip/admin for NAS running 4.1.x firmware. It does require ssh to install.
Entering https://nas-na...
Apr 07, 2022Guru - Experienced User
bekzclz11 wrote:
The ERR_SSL_VERSION_OR_CIPHER_MISMATCH error typically happens on older operating systems or browsers.
Not true. It's happening with current Chrome/Edge/Firefox on any OS. Probably current Safari also, but I haven't checked that.
Older browsers might give cert errors, but not this particular error. This is about browsers dropping support for TLS 1.0/1.1, and requiring TLS 1.2. It has nothing to do with certs. It's because the older ReadyNAS don't have TLS 1.2.
givememynamebak
Jan 21, 2023Luminary
StephenB- I think with any version of Firefox (I'm using latest to date 109.0 on a Mac) you can go to about:config and search for security.tls.version.min and change it to 1. Then you can get to FrontView on older ReadyNAS without needing specific versions of Firefox.
- StephenBJan 21, 2023Guru - Experienced User
That certainly is simpler than downloading an old version. Thx for sharing.
- SandsharkJan 22, 2023Sensei
The only concern with that is that if FireFox is your standard browser, then you'd also be allowing SSL 1.0 for external sites, which is not a good idea. With a separate version (which now could be a later one that previously suggested, however) that you are careful to only use for ReadyNAS access, you can more easily avoid that possibility.
I frankly don't understand why the browser publishers are so unaware of this problem and don't allow you to select SSL 1.0 for a specific address or range of addresses, maybe even including an easy selection of all local-only address ranges and/or limiting selection to those ranges. ReadyNAS is not the only older device with this issue.
- StephenBJan 22, 2023Guru - Experienced User
Yes that is the risk. Personally I prefer the patch to allow normal http connections for Frontview (and not allowing internet connections to the legacy NAS).
- givememynamebakFeb 15, 2023Luminary
StephenB- FWIW: Also in Firefox, you can also change security.tls.hello_downgrade_check to false to get rid of the TLS Security Warning where you have to click accept to proceed. I use Firefox on my home network and Chrome for everything else.
Also in windows 11, you can search for "Turn windows feature on or off" and check "SMB 1.0/CIFS File Sharing Support" to discover the network shares.
Thankfully they leave these as options for us!
- SandsharkFeb 15, 2023Sensei
givememynamebak wrote:StephenB- FWIW: Also in Firefox, you can also change security.tls.hello_downgrade_check to false to get rid of the TLS Security Warning where you have to click accept to proceed. I use Firefox on my home network and Chrome for everything else.
But, that does make the exception for all cases, which is probably a bad idea for external sites. So maintaining a separate install for ReadyNAS access is still a good idea.
