Feb 18, 2022Guru - Experienced User
Workaround for ERR_SSL_VERSION_OR_CIPHER_MISMATCH problem for Sparc NAS (4.1.x firmware)
This workaround eliminates the redirection of http://nas-name-or-ip/admin to https://nas-name-or-ip/admin for NAS running 4.1.x firmware. It does require ssh to install.
Entering https://nas-na...
Jan 22, 2023Guru - Experienced User
Sandshark wrote:
The only concern with that is that if FireFox is your standard browser, then you'd also be allowing SSL 1.0 for external sites, which is not a good idea.
Yes that is the risk. Personally I prefer the patch to allow normal http connections for Frontview (and not allowing internet connections to the legacy NAS).
SamirD
Mar 08, 2023Prodigy
Hence why I find just using portable ff 52 the easiest solution since it's just like having a proprietary software to access something.
