Feb 18, 2022Guru - Experienced User
Workaround for ERR_SSL_VERSION_OR_CIPHER_MISMATCH problem for Sparc NAS (4.1.x firmware)
This workaround eliminates the redirection of http://nas-name-or-ip/admin to https://nas-name-or-ip/admin for NAS running 4.1.x firmware. It does require ssh to install.
Entering https://nas-na...
givememynamebak
Jan 22, 2023Luminary
Sandshark- I agree it's a risk, but legit businesses have already been forced to upgrade. Its still a cipher, just no longer considered strong crypto. Nearly all sites these days are ssl/https with tls 1.2/1.3 which is mostly due to security paranoia but not all companies are transmitting data that are worthy of encryption outside of a normal login or a purchase. Any BigIP appliance like can decode https on the fly, so... there is that. I remember when 256bit encryption was a US only thing while 56bit was used outside the US due to US tech/crypto laws (which no-one seems to talk about anymore.) Some encryption is better than none and I see the risk as almost non-existent for TLS 1.0 sites these days. You're right, it doesn't seem like it would have been difficult to solve with your idea to supply an IP block. It would have been a better idea than just setting a global accept TLS 1 flag and would have worked into the future as well. They should have that across all browsers. The patch only works once you're into your legacy ReadyNAS for long term usage. If you have to do a factory reset, you still have to start with a supported browser unfortunately.
A better option would have been for these companies to support even their legacy products and supply a patch.
SamirD
Mar 08, 2023Prodigy
This is the crux of the problem of using legacy equipment though. The only way to avoid issues with legacy equipment is generally to just keep it 'period correct'. That does limit its usefulness, but its usefulness approaches nothing when trying to use it with 'modern' equipment. And this isn't an issue with just NAS units or Netgear or any brand or device--it is an age old problem that manufacturers have realized is their worst enemy to new sales so now 'forced obsolescence' is the new mantra. We're lucky these devices don't have a 'call home and die' feature.
