Feb 18, 2022Guru - Experienced User
Workaround for ERR_SSL_VERSION_OR_CIPHER_MISMATCH problem for Sparc NAS (4.1.x firmware)
This workaround eliminates the redirection of http://nas-name-or-ip/admin to https://nas-name-or-ip/admin for NAS running 4.1.x firmware. It does require ssh to install.
Entering https://nas-na...
givememynamebak
Mar 07, 2023Luminary
SamirD- As previously mentioned, you can also use any version of Firefox just set security.tls.version.min to 1 in about:config. I use Chrome or Edge for everything outside my network and the latest Firefox only for internal LAN for these reasons rather than maintaining a separate install/version.
nutsyboltsy- You can probably get it from his github instead of his debian repo here: https://github.com/rdynsxtrs/rn4bin
~Cheers
SamirD
Mar 08, 2023Prodigy
Good to know about the setting. Older software always runs so much faster on newer hardware, so I tend to fight any bloatware shoved down my throat. And my ff52 portable doesn't try to auto update so I can leave it and not worry. Good method to differentiate between lan and wan in terms of browsers but I've found every so often you need a specific browser for a specific site. Yes it's 2023 and some sites still play that game...
