Feb 18, 2022Guru - Experienced User
Workaround for ERR_SSL_VERSION_OR_CIPHER_MISMATCH problem for Sparc NAS (4.1.x firmware)
This workaround eliminates the redirection of http://nas-name-or-ip/admin to https://nas-name-or-ip/admin for NAS running 4.1.x firmware. It does require ssh to install.
Entering https://nas-na...
Mar 11, 2023Guru - Experienced User
SamirD wrote:
I remember when researching this upgrade for my ultra 6 that 4GB would make it run a better than 2GB.
If your system has two RAM slots, then 2x2GB is a good option. Though many OS 6 NAS run reasonably with 2 GB.
SamirD
Mar 13, 2023Prodigy
4GB even helps OS4 ime, and thanks to older posts here I believe I have a set of 8GB (2x4GB) modules that should allow me to get to 8GB. I might consider OS6 at that point, but still will keep with the 'if it isn't broken don't fix it' mentality I usually use with older hardware.
