Feb 18, 2022Guru - Experienced User
Workaround for ERR_SSL_VERSION_OR_CIPHER_MISMATCH problem for Sparc NAS (4.1.x firmware)
This workaround eliminates the redirection of http://nas-name-or-ip/admin to https://nas-name-or-ip/admin for NAS running 4.1.x firmware. It does require ssh to install.
Entering https://nas-na...
SamirD
Jul 26, 2024Prodigy
You're welcome! Definitely do not bin them if they're still working! My NVX is still running strong and probably will for a long time. In another 10 years these units will be in demand as they will be the only type of units that will work with computers from the same era as modern units won't work. And I'm lucky enough that old computers work fine for what I need daily, so if you ever find yourself not needing them anymore, please reach out to me and I can give them a new home.
givememynamebak
Jul 26, 2024Luminary
Same, my first Infrant RN600, NV+, Pro6 and 628x are ALL still going strong! I've even dockerized all my debian packages to install in /apps, show up in frontview apps with a toggle for OS6 and am able to update to "latest" docker images on most packages, except the few that require a newer docker (like Portainer) version than Debian Jessie provides. It should still last awhile I would think.
RIP Infrant/ReadyNAS!
