paul7290
Apr 04, 2019Aspirant
Ready cloud
Can anyone help I've bought a ultra 6 Nas and it was registered to the other owner so can I get this deregister with Netgear so I can use this on Netgears cloud Thank
Apr 04, 2019Guru - Experienced User
You can't re-register it, but I don't think you have to do that to run ReadyCloud.
You do need to conver the Ultra to run OS 6 firmware, since 4.2.x firmware isn't compatible with ReadyCloud. Have you done that?
- paul7290Apr 04, 2019AspirantNo I'm still running off 4.2.31 firmware what firmware do I need to upload to the ultra 6 to do this.
Also is this why I can't upload plex or any other firmware to the ultra 6- StephenBApr 04, 2019Guru - Experienced User
paul7290 wrote:
Also is this why I can't upload plex or any other firmware to the ultra 6Current versions of plex are for OS-6 systems, not 4.2.31. I don't know what other firmware you are trying to install, so no idea on that.
paul7290 wrote:
No I'm still running off 4.2.31 firmware what firmware do I need to upload to the ultra 6 to do this.Note you are on your own if you do this conversion - and you will lose Netgear support. That said, lots of people here have done it.
One thing to consider is whether you want to also increase the memory in the ultra 6. Currently shipping OS-6 systems all have at least 2 GB of RAM - your ultra only has 1 GB. Personally I suggest adding at least one more 1 GB module, or perhaps going with 2x2 GB. If youy want ot increase the RAM, I suggest doing that first.
Once you've done that, you'll need a full back up of the NAS, as the process is destructive.
There is a guide here: https://community.netgear.com/t5/Using-your-ReadyNAS-in-Business/Lost-contact-with-NAS-after-upgrading-Windows-10/m-p/1656875#M150811
- paul7290Apr 05, 2019AspirantThank you for your help I will sort the memory first and bigger drives as it's telling me there full .
My only concern is a full back does this mean copy every over to some where else as I've got 20tb of stuff on the ultra
