Guardshell
Oct 05, 2020Aspirant
Ready NAD Duo wiped drives and factory reset on its own
Hi
I have a ready nas duo v2 and 2x 2tb Wesatern digital drives installed ive had this for about 8-9 years and today I went to connect to the NAS and the IP had changed from the usual 192.168.1.6 thought it was strange upon my worst nightmare the NAS has decided to factory reset on its own I havent touched it for the past few weeks and as far as I knew the data was fine on there.
The nas has wiped both drives even though this was running on xraid2 redudancy :( is there any way I can get the data back? Im so annoyed that the NAS has decided to wipe itself!!!!
Please help!
What firmware are you running?
Have you downloaded the log zip file and looked for clues?
- GuardshellAspirant
Test
StephenB wrote:What firmware are you running?
Its the latest firmware all I can see is that it decided to wipe everything on the 21st september no information why
Sep 21 14:44:53 nas-BE-F8-F4 syslogd 1.5.0#6: restart.
Sep 21 14:44:53 nas-BE-F8-F4 kernel: klogd 1.5.0#6, log source = /proc/kmsg started.
Sep 21 14:44:53 nas-BE-F8-F4 kernel: Linux version 2.6.31.8.duov2 (root@NSBU-NJ) (gcc version 4.3.2 (sdk3.2rc1-ct-ng-1.4.1) ) #1 Thu Apr 18 18:24:47 HKT 2013
Sep 21 14:44:53 nas-BE-F8-F4 kernel: CPU: Feroceon 88FR131 [56251311] revision 1 (ARMv5TE), cr=00053977
Sep 21 14:44:53 nas-BE-F8-F4 kernel: CPU: VIVT data cache, VIVT instruction cache
