Stuart3142
Sep 09, 2021Aspirant
Ready Nas 102 no web admin
Hi All,
My 102 did an upgrade to 6.10.5 and I lost the admin, blank page, could not establish a connection. Reading the admin site I rolled back to 6.10.4 still no login same error. The NAS still functions.
I have SSL and FTP access. It looks like apache2 will not start due to an error in the apache2.pem file.
I have attached below the start process. I hope someone can help. Sorry about the formatting!
root@NAS102:/etc/init.d# ./apache2 start
[....] Starting apache2 (via systemctl): apache2.service
Broadcast message from systemd-journald@NAS102 (Thu 2021-09-09 14:12:55 WEST):
apache2[604]: [ssl:emerg] [pid 604] AH02562: Failed to configure certificate fe80::eafc:afff:fee4:c025:443:0 (with chain), check /etc/frontview/apache/apache2.pem
apache2[604]: [ssl:emerg] [pid 604] SSL Library Error: error:0906D06C TongueEM routines TongueEM_read_bio:no start line (Expecting: TRUSTED CERTIFICATE) -- Bad file contents or format - or even just a forgotten SSLCertificateKeyFile?
apache2[604]: [ssl:emerg] [pid 604] SSL Library Error: error:140DC009 FrustratedSL routines FrustratedSL_CTX_use_certificate_chain_file TongueEM lib
Job for apache2.service failed because the control process exited with error code.
See "systemctl status apache2.service" and "journalctl -xe" for details.
failed!
apache2[611]: [ssl:emerg] [pid 611] AH02562: Failed to configure certificate fe80::eafc:afff:fee4:c025:443:0 (with chain), check /etc/frontview/apache/apache2.pem
apache2[611]: [ssl:emerg] [pid 611] SSL Library Error: error:0906D06C TongueEM routines TongueEM_read_bio:no start line (Expecting: TRUSTED CERTIFICATE) -- Bad file contents or format - or even just a forgotten SSLCertificateKeyFile?
apache2[611]: [ssl:emerg] [pid 611] SSL Library Error: error:140DC009 FrustratedSL routines FrustratedSL_CTX_use_certificate_chain_file TongueEM lib
You need hotfix 1 with 6.10.5. Is the NAS able to reach the internet?
How did you downgrade?
- Stuart3142Aspirant
I am on 6.10.4 now and I can ping my main name server, so yes I can see the wan/internet.
I down graded using the command line.
How do I get hot fix 1?
But the hotfix is specific to 6.10.5
Did you reboot after you downgraded?
