RichardB56's avatar
RichardB56
Apprentice
Apr 14, 2024
Ready NAS 212 Fails to Complete Setup
ReadyNAS 212 2-bay I had drive failures. I was able to back up my data to another NAS.  I installed 2 4TB SSDs and want to start for scratch.  I started RAIDar app.  At first it found the NAS and th...
  • StephenB's avatar
    Apr 17, 2024
    RichardB56 wrote:
    After a minute the power light blinks and the Drive1, Drive 2 and back light blink but power light first and then the others. Flashing back and forth.
    Does the status match one of these patterns:
    LED blink behavior for 2 disk systems is three quick blinks of all disk LEDs and the backup LED, followed by an 1s delay, followed by a number of slow blinks.  The number of slow blinks will be the error code.
    Current error codes:
    1  - Vendor mismatch
    2  - No disks detected
    3  - Bad contents on root partition of disks
    4  - Flash error
    5  - Unsupported RAID configuration
    RichardB56 wrote:
    I have connected the SSDs to my PC and they are working.
    That said, your symptoms sound like they might disk-related.  Did you run a full disk test?
    RichardB56 wrote:
    I tried accessing the NAS through the browser using the IP and get asked for a password that I do not have.  I tried 'admin" without a password but it does not work.
    The default admin password is "password".
    FYI, manuals for your NAS are here:
ProSupport for Business
