GreaseKnuckles
Sep 24, 2020Follower
Ready NAS Duo not detected by windows 10 after factory reset
I have acquired a used Ready NAS duo from a nephew and a factory reset has been done. I have attempted to install Raidar and received java script missing errors. My windows 10 laptop has not detected...
JohnCM_S
Sep 24, 2020NETGEAR Employee Retired
Hi GreaseKnuckles,
Welcome to the Community!
May I know which version of your RAIDar you installed? Have you tried un-installing then re-installing it?
You cannot connect the PC to the NAS via USB cable. The USB ports on the NAS are used for USB drives for backup. The NAS needs to be connected to your network via Ethernet cable.
