raluc's avatar
raluc
readycloud app not backing media
everything was working  just fine i did new update on iphone 6 and now my media wont backup on the  phone app i get uploading but it stays stuck and wont copy the photos
  • Hello :smileyhappy:
    ReadyCLOUD App media backup works in my iPhone 5s.
    iOS 11.2.5
    ReadyCLOUD App v2.0.0
    Are you trying to backup your media files from iOS via WiFi or mobile data? If you are using mobile data make sure  enable Use Cellular Data and if you want the media files to be backup automatically make sure to enabled Backup in Background.
  • I am having the exact same issue.  I am using an ipad with the latest ios version 11.2.1 and using the latest readycloud app.  When I enable media backup and choose my folder, it says "uploading 60 files" and shows a status bar that just hangs and it doesn't upload.  Does anyone know how to fix this issue?  Very frustrating.  I have a Nighthawk R7000 router with a USB harddrive.  Readycloud works fine from a web browser.
    • Lucha's avatar
      Lucha
      No seems to be able to help here
      I called netgear and payed for 85.00 for tech support and they had no clue either
      I guess i will have to go a different route
      • Marc_V's avatar
        Marc_V
        NETGEAR Employee Retired
        Hi raluc Lucha
        Would you be able to try and reinstall the ReadyCloud app and try to backup media.
        Please confirm if the issue has been resolved.
        Many thanks!
ProSupport for Business
