Mianali
Oct 07, 2023Follower
ReadyCloud is not working
i have readyNAS 516 Everytime i click on ReadyCloud website redirect to netgear website under the cloud Readycloud is On, Internet Available is green check but getting error unable to register the ...
Kitsap
Oct 07, 2023Master
Mianali wrote:i have readyNAS 516
under the cloud Readycloud is On, Internet Available is green check but getting error unable to register the device.
I have rebooted the NAS few times still the same issue
ReadyCloud has been depreciated.
https://kb.netgear.com/000065438/Support-for-ReadyCLOUD-feature-ends-spring-2023
tigerten
Oct 08, 2023Luminary
This is why a new firmware is needed to clean up.
- michaelkenwardOct 09, 2023Guru - Experienced User
Can you explain what that means?
What do you need to clean up?
If you have a problem with an NAS, seek help in the appropriate section.
ReadyNAS Network Storage: Official NETGEAR Community
If you are talking about a router, there is nothing to clean up. ReadyCloud is dead.
- StephenBOct 09, 2023Guru - Experienced User
Today there are dysfunctional controls and software that doesn't work but still consume some system resources, and maybe even longer term some security risks.
There should be an update that fully removes the ReadyCloud service from the NAS, and also removes the ReadyCloud users (today left-over ReadyCloud accounts on the NAS cannot be removed or edited, as attempts to do that are redirected to the removed ReadyCloud site).
Not related to ReadyCloud, but another cleanup needed on app install, to account for archival of Debian 8 archives.
Both are easy for Netgear to do, and would be very helpful for a number of ReadyNAS owners.
michaelkenward wrote:seek help in the appropriate section.
ReadyCloud has always been a bit of a mess in that regard, since the service included both routers and NAS. There have always been ReadyCloud+router issues posted in the NAS forum area, and some NAS+ReadyCloud issues posted in the router areas.
OK. An NAS issue best discussed in the correct place.
The equivalent issue in routers is a redundant link to ReadyCLOUD in ReadySHARE set up. That's not likely to eat resources. Hardly worth rewriting the firmware for ancient routers, now that Netgear is trying to wean people off USB support of any sort by removing it from newer models.
