Cain1
Nov 14, 2010Aspirant
ReadyNAS® Pro vs ReadyNas Ultra Plus ??
What exactly are the differences between these two?? I see lots of info on the Ultra and Ultra Plus but less info on the Pro. Thx !!
regnav
Nov 17, 2010Aspirant
yoh-dah/mdgm thanks for the information. So I will be able to run Orb, ReadyDLNA, Skifta etc.? I noticed that you called the ultra x86. Is the pro based on intel processor as well?
If I am understanding you correctly, I will have to snap each volume on the pro, and then run a backup job of those snaps to the NV. Is there a way to just schedule the snaps and after the snap is comlete, have those snaps replicate over to the NV?
Is there additional software that I will have to purchase to snap and replicate?
