Cain1
Nov 14, 2010Aspirant
ReadyNAS® Pro vs ReadyNas Ultra Plus ??
What exactly are the differences between these two?? I see lots of info on the Ultra and Ultra Plus but less info on the Pro. Thx !!
mdgm-ntgr
Nov 17, 2010NETGEAR Employee Retired
I think you are misunderstanding what the Frontview snapshot feature is for. You take the snapshot on the Pro and then backup the snapshot to the NV. The Pro has a single snapshot that can be active at any one time. If the snapshot space runs out it will be invalidated. To create a new snapshot you have to delete the old one (you can schedule snapshot creation).
