Cain1's avatar
Cain1
ReadyNAS® Pro vs ReadyNas Ultra Plus ??
What exactly are the differences between these two??
I see lots of info on the Ultra and Ultra Plus but less info on the Pro.
Thx !!
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    The Ultra 6 doesn't even max out a gigabit connection so LACP would probably just provide the benefit of failover if it were available.
    It does make a performance difference on the Pro Business, but you need multiple client machines or a single client machine with a SSD and/or RAID array to notice it.
    Thx !!
    Just opened my ReadyNAS Ultra 6 plus, and to my surprise found a E5300 (2.6 GHz processor) and not the advertised E2160 1.8Ghz CPU !
    http://home.bott.ca/webserver/?p=499
    mdgm-ntgr
    Good for you! The E5300 is the CPU used in the Pro 6.
    Not good for me if the only reason I opened it was to upgrade the processor. Had already gone to the trouble of purchasing the same E5300 processor from eBay :oops:
    you can imagine the look on my face.....screw driver in one hand and paste in the other !
    only joking :neener:
  • lesson learned? next time you go to upgrade something, be sure of what you already have first :)
    indeed!
    have E6700 SL9ZF on order which should be arriving soon
    along with Crucial CT25664AA1067 (2x2GB chips)
ProSupport for Business
