levy1983
Jun 30, 2017Aspirant
ReadyNAS 102 TFTP_REQ problem
Hi Everybody,
I have a ReadyNAS102. I switched off my router and NAS for 8-10 days. Yesterday I switched on everything, but my NAS is not working. The power LED is blinking, but nothing else. I can't switch off the NAS, I can't connect to it. Boot menu is working and I was able to update the firmware via USB drive (first to 6.7.5, than back to 6.6.0), but RAIDar shows me the status is: TFTP_REQ. I can ping it, but nothing else. I don't want to do a factory reset, because I need my data from the NAS. Could anybody help me, please?!
Thanks in advance.
One option is paid support at my.netgear.com (booting up the NAS into tech support mode). Ask about per-incident support.
If you have USB devices connected (including a UPS) try disconnecting them all and see if that makes any difference. (Likely won't, but worth a try). If that doesn't help, perhaps try the USB recovery again.
- levy1983Aspirant
Thanks for your answer. No USB device, just an ethernet cable to the router. I updated the firmware few times with 3 different pendrive, 3 different fw version, but with the same result: "TFTP_REQ". If I do a factory reset with no drive or other drive, and I reboot it with original disks? Will this destroy my data?
You can't do a factory reset with no drives in place. The reset does a factory install to the hard drives.
At this point you might need support's help (though the US holiday would slow that down).
Was there a reason you did a USB recovery to update the firmware?
