No1Husker
Dec 02, 2020Aspirant
ReadyNas 104 - ReadyCloud one folder will no longer open
I am using an RN10400 that has been working great for several years. Today I have just one folder that I save movies into that when I click on the folder in ReadyCloud it will not open that folder. A...
Dec 03, 2020Guru - Experienced User
What firmware are you running?
Can you access the folder without using ReadyCloud?
Have you downloaded the log zip file from the admin web ui, and looked for btrfs errors in system.log and kernel.log?
