No1Husker
Dec 02, 2020Aspirant
ReadyNas 104 - ReadyCloud one folder will no longer open
I am using an RN10400 that has been working great for several years. Today I have just one folder that I save movies into that when I click on the folder in ReadyCloud it will not open that folder. A...
No1Husker
Dec 03, 2020Aspirant
Thank you for the reply, I am inexperienced in working with my ReadyNas. I have had it for several years and it has just worked for the basic things that I do. I am saving our family movies, pictures, videos and old super 8 films. I have set up a Plex account in the last six months that has also been working fine. I am also using backup for a couple of iPhones.
I am on a Mac, but I do have access to a Windows machine for access, just don't use that machine very often.
Firmware: 6.10.3
I am able to open my shared folder in Finder, initially I do see all of my folders. I am able to open all of the folders with the exception of the Movie folder, which when I click it I receive an error message that states, "The operation can't be completed because the original item for "Movies" can't be found." You can then click OK and Finder closes.
I have not downloaded the log zip file from Admin, I will attempt that now. I am not very familiar with Administration.
I was able to pull the btrfs errors in system.log. This is a long string of information, what am I looking for? Will is say error or something? There are a long string of snapshots and then at the bottom some reference to:
=== btrfs dump-super /dev/md126 /dev/md127
superblock: bytenr=65536, device=/dev/md126
and then references to backup.
My Kernal log is pretty long, what would I be looking for in this one?
Thanks,
Randy
- StephenBDec 04, 2020Guru - Experienced User
The logs can be long and confusing. The btrfs errors should include the word "error", so you can just search on that. The mods can also analyze them for you - but please don't post links to them in the public forum.
Is "Movie" a share or is it a folder inside of a share? Did you try navigating into it from the admin web ui?
- No1HuskerDec 04, 2020Aspirant
It is set as a share with "Everyone" listed. I have another folder set the same and with "Everyone" and it opens.
I did realize yesterday that it was no longer sending me messages, because I had changed my email password about a month ago and did not undated the password in my ReadyNAS Admin.
This morning I receive the attached email that I had received in the past before the password change. Maybe this is associated?
Randy
It could be related to your problem, and it is something you need to get fixed.
- Netgear paid support (via my.netgear.com) is one option - they can fix it remotely. You should look for per-incident support if you go this route (it should be cheaper than getting a normal NAS support contract).
- You could also back up all the files and do a factory default - setting up the NAS from scratch.
- If you are skilled with linux commands, you could also enable ssh, and resolve this yourself.
Just an update to your last message. I did a search in the brtfs.log for "error" and found none.
In the Kernal.log and did find some overrun errors. I would past one here, but I am not sure that is safe?
Randy
You can post the errors in kernel.log.
