VTo103
May 13, 2025Aspirant
ReadyNas 104 PSU problems, Volume is Dead now
Suspecting a dodgy power supply caused this mess: 12 May 2025 03:23:48 Volume: Volume data health changed from Dead to Inactive. 12 May 2025 01:00:24 Volume: Volume data is Dead...
VTo103
- Disks were not removed at all
- the only explanation of the disk removal events are form low power
- PSU was replaced an hr or so before the post, 15hrs after this:
May 14, 2025Guru - Experienced User
VTo103 wrote:Disks were not removed at all
Get the full log zip (if you haven't already). If you want me to take a look, then upload it into cloud storage (dropbox, google drive, etc), and send me a private message (PM) with a link using the envelope icon in the upper right of the forum page. Make sure the permissions are set so anyone with the link can download.
Best not to post the link in a public forum, as there is some privacy leakage when you do that.
