ma33axaka
May 19, 2018Aspirant
Readynas 104 SMB won't activate
Been using it for almost 2 years and no problem.
All of suddent I can't enalbe SMB. Did a OS reinstallation, and upgrade to 6.9.4-T8, non of them helped.
I did some research and the only way is t...
- May 19, 2018
I tried so:
apt-get remove samba samba-common smbclient swat samba-doc smbfs libpam-smbpass libsmbclient libsmbclient-dev winbind
This removes all samba-related packages.
Then:
apt-get install samba
Then reboot and:
systemctl status -a smb
give:
root@NAS:~# systemctl status -a smb ● smb.service - Samba SMB Daemon Loaded: loaded (/lib/systemd/system/smb.service; enabled; vendor preset: enab led) Active: active (running) since Sat 2018-05-19 16:30:45 MSK; 19min ago Main PID: 2219 (smbd) Status: "smbd: ready to serve connections..." CGroup: /system.slice/smb.service ├─2219 /usr/sbin/smbd --foreground --no-process-group ├─2325 /usr/sbin/smbd --foreground --no-process-group ├─2326 /usr/sbin/smbd --foreground --no-process-group ├─2355 /usr/sbin/smbd --foreground --no-process-group └─3723 /usr/sbin/smbd --foreground --no-process-group May 19 16:30:39 NAS systemd[1]: Starting Samba SMB Daemon... May 19 16:30:45 NAS systemd[1]: Started Samba SMB Daemon. May 19 16:30:45 NAS smbd[2219]: [2018/05/19 16:30:45.997388, 0] ../lib/ util/become_daemon.c:124(daemon_ready) May 19 16:30:46 NAS smbd[2219]: STATUS=daemon 'smbd' finished starting up and ready to s
ma33axaka
Purge & reinstall samba do not given the effect
ma33axaka
I tried so:
Then:
Then reboot and:
give:
led)
ago
up and ready to s
