RichardCDL
Sep 19, 2020Tutor
ReadyNAS 212 Disconnects Randomly From Samsung TV
I have a ReadyNAS 212 running OS 6.10.3 connected to a number of devices over a gigabit ethernet. One of the devices is a Samsung Series 6 Smart TV UK43KU6400. I can navigate to the NAS and play bo...
Mauser69
Sep 20, 2020Tutor
I cannot tell you what might be causing your particular problem, but I did want to say that I am using the ReadyDLNA with my RN214 and a Samsung TV, and my TV has never had a problem playing completely through any movies or other videos on the NAS. So hopefully someone here can help you identify what is going on with your system.
- RichardCDLSep 27, 2020Tutor
Is this the best reply that is on offer here?
- StephenBSep 27, 2020Guru - Experienced User
Not sure what you think the "best reply" is. I did suggest installing plex, and enabling it's DLNA server (disabling ReadyDLNA) and see if that makes any difference.
It's hard to say if your issue is caused by the TV or by the NAS.
