TKovacs
Dec 05, 2016Aspirant
ReadyNAS 2120 not seeing 5 TB USB Drive
I'm having a problem where my ReadyNAS 2120 isn't recognizing my Seagate SRD0NF2 5 TB USB 3.0 Expansion Desktop Drive. I've formatted the drive on my PC and can read/write to it without any issue...
- Dec 05, 2016
Release notes and the beta itself are here: https://community.netgear.com/t5/ReadyNAS-Beta-Release/ReadyNASOS-6-6-1-T207-Beta-2/m-p/1172692#U1172692
Note entry 9 in the changelog.
Dec 05, 2016Guru - Experienced User
What firmware are you running in the NAS?
There is a USB fix in 6.6.1 beta.
TKovacs
I'm using 6.6.0. What exactly are the details of the 6.6.1 USB fix, and how can I go about getting it?
Thanks!
- StephenBDec 05, 2016Guru - Experienced User
- TKovacsDec 09, 2016Aspirant
This did the trick for me! The unit is now able to recognize the 5 TB drive. Thanks for your help!
