bastelspezi
Jun 03, 2016Aspirant
READYNAS 214 wont show smart values
hey guys is there any knows issue with a READYNAS214 and a seagate NAS drive 6TB model st6000vn0021. cuz my nas wont show its smart values ever since I've inserted it nor does it show the correct temperature, which shows -1. might this be fixed with an firmware update on either the nas or the harddrive?
thanks so much in advance
Good Grief. The st6000vn0001 is on the list, but the st6000vn0021 is the currently shipping model. Are you serious?
- LaserbaitLuminary
Hello StephenB,
So is that how it works in th HCL for Seagate? If the ST6000VN0001 is on the HCL, then all ST6000VN00X1's are, or, should be supported?
Thanks!
- mdgm-ntgrNETGEAR Employee Retired
Which firmware are you running? If not already running ReadyNAS OS 6.6.0 please note there are some changes in that release which should resolve this.
Bug fix #16: "Updated the drive monitoring tools to work with the modern drive standards."
