dbarkley
Aug 02, 2011Aspirant
ReadyNAS 3100 or Pro6
I am just starting to look for a NAS device and came upon the netgear solution. Both Models, the 3100 and the pro6, have been recommended but which one should I choose. This is going to be in a busi...
yoh-dah
Aug 02, 2011Guide
The 3100 is a rackmount, and has redundant power supply. The Pro 6 is a desktop model supporting up to 6 drives, allowing for better capacity utilization in dual redundancy mode, and with quite a bit less noise. Performance should not be a problem with either of these devices as they can handle more than the gigabit bandwidth internally. Both are good solutions -- you just need to decide what's more important in your environment.
