robjd
Jun 15, 2016Aspirant
ReadyNas 3220 volume degraded
We cannot write any data to our data share anymore .... it doesnt seem like a security issue. On the Admin page the volume is showing as degraded. i am now running a SCRUB on this volume. Ca...
Jun 15, 2016Guru - Experienced User
Running a scrub when the volume is already degraded is risky - if any disk failures occur the volume can be lost.
Whenever you see a degraded volume, the first thing to check is the disk status. That includes downloading the log and reviewing the SMART stats.
robjd
Thanks for your reply.
All of the disks are showing 0 errors and ONLINE status.
What should I focus on in the logs please?
- StephenBJun 15, 2016Guru - Experienced User
It might be faster if you use Netgear support.
Your volume is very full, and that might be part of the problem.
- Retired_MemberJun 15, 2016
robjd wrote:What should I focus on in the logs please?
The volume is most likely full(y allocated).
Download the logs, and check btrfs.log
Label: foo uuid: bar Total devices 1 FS bytes used <actual data in volume> devid 1 size <volume capacity> used <data allocation> path /dev/sddif <data allocation> is the same as <volume capacity>, that's most likely the source of your issue.
- robjdJun 16, 2016Aspirant
Thansk for your response!.
Will check this out.
Rob
- mdgm-ntgrJun 16, 2016NETGEAR Employee Retired
We'd recommend keeping volume usage under 80% full.
if the space is fully allocated you may wish to update your backup, free up some space and then once volume usage is below about 80% run a balance.
Do you use snapshots?
Can you send your logs in (see the Sending Logs link in my sig)?
