robjd
Jun 15, 2016Aspirant
ReadyNas 3220 volume degraded
We cannot write any data to our data share anymore .... it doesnt seem like a security issue. On the Admin page the volume is showing as degraded. i am now running a SCRUB on this volume. Ca...
robjd
Thanks for your reply.
All of the disks are showing 0 errors and ONLINE status.
What should I focus on in the logs please?
Jun 15, 2016Guru - Experienced User
It might be faster if you use Netgear support.
Your volume is very full, and that might be part of the problem.
