E1b0t
Nov 07, 2016Tutor
ReadyNAS 3312 10TB Drives
Website (http://netgear.com/business/products/storage/readynas/readynas-rackmount.aspx?cid=wmt_netgear_organic) advertise space up to 120TB but no 10TB drives on the compatibility list. When will the...
E1b0t
Nov 08, 2016Tutor
WillI be able to use the WD4002FYYZ (4TB, WD Gold, Enterprise) drive in the unit? This one is also not on the list, but it is an enterprise drive
mdgm-ntgr
Nov 08, 2016NETGEAR Employee Retired
Disks not on the list may be incompatible. On the other hand they may work fine.
Only enterprise disks are suitable for the RR3312
- E1b0tNov 08, 2016Tutor
When is the last time the list was updated? As per original post, not even 10TB are on the list with the website states it is supported. The outdated compatibility list makes it difficult to sell NAS solutions.
