jpttpiotr's avatar
jpttpiotr
ReadyNAS 4 Ultra it is not visible resources
Hi
Serial number : 2DK6190301627
Firmware : 4.2.26, raid 5
Starting RAIDar I receive the information that the excellent form.
From the application level I log in to organizing, participations are visible.
From the level of the computer (Windows 10 ) are not visible participations, what this it {he, she} I is going do not have the data access.
All acted {worked} well, to the moment I wanted to add the task copyable, after the record all tasks disappeared.
I switched off, I included {switched on} the server US and thenceforward I do not have the access to resources.
Thank you too {for} the all help, I have there important data
    • BrianL2's avatar
      BrianL2
      NETGEAR Employee Retired
      Hi jpttpiotr,
      Welcome to the community!
      Do you have RAIDar installed in your PC? Use it to detect your ReadyNAS Ultra 4 in your network. If it sees it, try to check if you can access the admin page. If not, check you local network connection and tell us the LED pattern or LCD status on the front panel.
      I look forward to your response.
      Kind regards,
      BrianL
      NETGEAR Community Team
      • jpttpiotr's avatar
        jpttpiotr
        Hi
        Thank you the answer :
        1. RAIDar installed on a computer finds ReadyNAS and shows all diodes on in green,
        2. From the computer I unite to the device as admin, as if all OK, volumes it is visible {apparently}, however I cannot record no changes of the configuration, simply they do not enter .
        3. Ping to the device acts {works},
        4. On the device the panel shows the address ip and the quantity  of the vacant seat on disks, that is OK.
        5. From the level Exploratora Windows of the device it is not visible {apparently}, what I additionally suppose is a result of the lack of the service making available resources for the system Windows
        I greet
        jpttpiotr
ProSupport for Business
