TOM2806
Jul 09, 2018Aspirant
ReadyNas 516 doesn't reach BOOT
Sorry, need your help. I am using my 516 already some years w/o any problems. Raid5 was installed (not XRAID). I exchanged two HD's (one after each other) and sync went well. With Raidar I saw that b...
- Jul 09, 2018
Can't belive it. After two days of frustration on hell of lost nerves I write here in the forum and one minute later the system starts itself (without any impact from my side) to boot. So seems topic can be closed. I will confirm it finally tomorrow (simply wanted to safe your time).
TOM2806
mdgm-ntgr
Jul 09, 2018NETGEAR Employee Retired
I agree you should check through the logs. You can send those in if you like (see the Sending Logs link in my sig).
