Alex8
May 08, 2017Tutor
Readynas 524x EDA500 compatibility
Hello, I am considering the readynas 524 as it is the only affordable NAS featuring ECC ram that I could find. The specs mention that it has 1 esata port but doesn't mention compatibility with t...
- May 08, 2017
The RN524X is incompatible with the EDA500.
Alex8
May 08, 2017Tutor
Thanks for your answer.
The eda500 appears to be officially supported in the 526x 528x 626x and 628x documentation, but not in the 524x documentation. That is why I am worried about buying it.
I cannot find any 12TB drives yet here in Canada and I was going for 8tb drives as these have currently the best value. You are right that I would get plenty of space with 10 or 12 tb drives in raid 5 (x-raid).
I know that raid is not a backup but I was looking at raid 10 for extra reliability and less rebuild time with such large drives. With only 4 slots, I guess I would have to go with flex raid.
May 08, 2017Guru - Experienced User
RAID 10 requires flexraid. XRAID blends RAID 1, 5, and 6 (depending on the drive mix and the redundancy).
I agree 8 TB is the best value at the moment. Note that if the drive doesn't have the side mounting holes, you can remove the plastic inserts and screw the drives into the bottom of the tray. FWIW, the WDC Red (WD80EFZX) does have the side mount holes.
- hmuessigMay 08, 2017Luminary
An "official" answer from Netgear would be appreciated as I too am considering a 52xx series box and have (am very happy with the EDA500).
Thanks!
