dctomlinson
Mar 14, 2012Aspirant
ReadyNAS 600 data recovery
I have a ReadyNAS 600 which I used extensively for storing music, video, etc. During a thunderstorm, I lost power. When the power came back, the device started a recovery process, during which another power outage occurred. After the 2nd recovery completed, the directory showed zero files. Is this recoverable? Is there a utility?
When this happened, I decided not to use the device until I could spend some time addressing the issue, since I wanted to recover the files.
Well, it's been a while, when this happened, Infrant was still the vendor and was always helpful. How will Netgear change the equation?
David Tomlinson
david@davidctomlinson.com
David Tomlinson
1 Reply
- mdgm-ntgrNETGEAR Employee RetiredWhat brand and model disks installed and how many?
What version of RAIDiator is on the unit?
Did you download the logs (Status > Logs > Download all logs)?
