jcdick1
Dec 08, 2020Aspirant
ReadyNAS 628X - can't browse directory
I have a directory on my ReadyNAS that I can't browse via the web GUI. Is there a file count limit that would cause the GUI to fail to open a directory? The progress bar just zooms across the top o...
Marc_V
Dec 09, 2020NETGEAR Employee Retired
Welcome to the Community!
Have you tried using a different browser? are you having issues as well when accessing the shares locally thru Windows explorer? If not, it might be possible due to the large quantity of data and the connection you have. it takes time to display the details.
But if you are experiencing other issues aside from this one, it might be worth it to check the logs.
HTH
