givememynamebak
Dec 16, 2022Luminary
ReadyNAS 628X - KEYEXPIRED & Hash Sum mismatch - Debian jessie
I'm deeply regretting my 628x purchase in 2019 (still under warranty I believe) since Netgear seems to have completely abandoned ReadyNAS product. Debian Jessie is old has also been archived. They r...
givememynamebak
I should mention, this is all after creating a new volume and a factory reset with OS 6.10.8. Thoughts anyone?
- givememynamebakDec 19, 2022Luminary
Each one of these is after a fresh install and factory reset:
ReadyNAS OS 6.10.8
E: Failed to fetch https://apt.readynas.com/packages/readynasos/dists/6.10.8/main/pool/l/linux/linux-libc-dev_4.4.218.1_amd64.deb Hash Sum mismatch- Did someone manually update some files in the repository and forget to update the checksums.
ReadyNAS OS 6.10.7
Err:25 https://apt.readynas.com/packages/readynasos 6.10.7/main amd64 libc-dev-bin amd64 2.19-18+deb8u10.netgear1 403 Forbidden- This happens when a file is listed in the NTGR repo package list but isn’t actually in the repo.
What's going on Netgear? It certainly would be nice if Netgear would just opensource ReadyNAS OS6 so the community can maintain it if they're no longer willing too!
- StephenBDec 20, 2022Guru - Experienced User
- givememynamebakDec 29, 2022Luminary
