givememynamebak
Dec 16, 2022Luminary
ReadyNAS 628X - KEYEXPIRED & Hash Sum mismatch - Debian jessie
I'm deeply regretting my 628x purchase in 2019 (still under warranty I believe) since Netgear seems to have completely abandoned ReadyNAS product. Debian Jessie is old has also been archived. They r...
JeraldM
Jan 02, 2023NETGEAR Employee Retired
Thanks for the ping StephenB!
Hi givememynamebak,
I've relayed this information to our L3 Engineers.
Please bear with us and thank you for your patience.
JeraldM
NETGEAR Community Team
- mataglap2Jan 02, 2023Tutor
Regarding the Debian repos, they have moved the jessie repos to http://archive.debian.org/debian/dists/jessie/ and there are different keys, see http://archive.debian.org/debian/pool/main/d/debian-archive-keyring/
Presumably, /etc/apt/source.list needs to be updated with the archive repo locations, and archive keyring package installed.
- givememynamebakJan 02, 2023Luminary
mataglap2 - Good point. I saw that too.
Marc_Vand JeraldM - can you please include a patch or hotfix with the updated keys and sources.list for debian jessie since it's now been moved to archive? And as a special request, make ReadyNAS OS6 including readynasd open source so the community can keep things updated?
Thank you!
- tigertenFeb 13, 2023Luminary
I have similar issues. Look forward to an hotfix as well.
- GroguMar 19, 2023Guide
Have same problem with ReadyNas 526x but it seems that Netgear have no longer interest in supportting ex-customers. Its a pitty, despite the time of launch of Netgear products it still can operate (mine still operates with Docker strenghtened with additional 16 GB memory - however more and more images refuse to work due to oudated docker/system version). Having opportunity to install other OS supported by community as FreeNas, Open Media Vault, TrueNas or similar, would save CO2 and the planet ( correct Netgear Team??? 😆 )
For me personally it is painfull as I trusted Netgear having : Orbi, Arlo and two ReadyNas and sadly it seems to be a wrong choice.
- givememynamebakMar 19, 2023Luminary
Grogu- I created a ReadyNAS debian package for 19.03.9 which should buy more time. It's available here under releases: https://github.com/jdnowak/readynas_docker
Make sure you shut off docker in frontview before installing as mentioned in the README.md or this git issue: https://github.com/jdnowak/readynas_docker/issues/2
~Cheers
- GroguMar 20, 2023Guide
I did it 2 weeks ago 🙂 still have problems (i.e. Calibre Web) , anyway thanks for sharing 🙂
Im afraid that Netgear will ignore above requests as they do not care of ex-customers they already monetized their product so what can we do ?
I'm convinced that the only way is to figure out how to do It oursevles and avoid Netgear products in the future
I found something for 424 not sure if it is aplicable for 526x or 628x :
JeraldM- Any status updates on this?
- StephenBMar 19, 2023Guru - Experienced User
FYI, he is no longer with Netgear.
- tigertenMar 19, 2023Luminary
Are there still any MODs/Admin here working with Netgear? It appears the channel of communications between customers and Netgear has completely closed.
