givememynamebak
Dec 16, 2022Luminary
ReadyNAS 628X - KEYEXPIRED & Hash Sum mismatch - Debian jessie
I'm deeply regretting my 628x purchase in 2019 (still under warranty I believe) since Netgear seems to have completely abandoned ReadyNAS product. Debian Jessie is old has also been archived. They r...
Grogu
Mar 19, 2023Guide
Have same problem with ReadyNas 526x but it seems that Netgear have no longer interest in supportting ex-customers. Its a pitty, despite the time of launch of Netgear products it still can operate (mine still operates with Docker strenghtened with additional 16 GB memory - however more and more images refuse to work due to oudated docker/system version). Having opportunity to install other OS supported by community as FreeNas, Open Media Vault, TrueNas or similar, would save CO2 and the planet ( correct Netgear Team??? 😆 )
For me personally it is painfull as I trusted Netgear having : Orbi, Arlo and two ReadyNas and sadly it seems to be a wrong choice.
givememynamebak
Mar 19, 2023Luminary
Grogu- I created a ReadyNAS debian package for 19.03.9 which should buy more time. It's available here under releases: https://github.com/jdnowak/readynas_docker
Make sure you shut off docker in frontview before installing as mentioned in the README.md or this git issue: https://github.com/jdnowak/readynas_docker/issues/2
~Cheers
- GroguMar 20, 2023Guide
I did it 2 weeks ago 🙂 still have problems (i.e. Calibre Web) , anyway thanks for sharing 🙂
Im afraid that Netgear will ignore above requests as they do not care of ex-customers they already monetized their product so what can we do ?
I'm convinced that the only way is to figure out how to do It oursevles and avoid Netgear products in the future
I found something for 424 not sure if it is aplicable for 526x or 628x :
