Turbogutten
Oct 30, 2018Aspirant
ReadyNas and Asus RT-AT3200 Router
- My old router just died, and I bought a Asus RT-AC3200 router and updated it to latest firmware.
I hooked up my Netgear ReadyNas Duo to the new routers lan port and powered it on.
The Netgear ReadyNas Duo is set up to automatically recieve ip adress through DHCP from the router, but it does not show up as a detected unit in the Asus RT-AC3200 admin page, and I am not able to detect it on network or by RaidAr program?
I thought this router provided easy "plug and play" features, or Is it just not possible to connect a ReadyNas Duo to this router ?
Are there any settings in the Asus router I will have to do ?
I have no problem accessing the ReadyNas Duo when connecting directly to a computer, restarting it, and then use the default login ip 192.168.168.168/admin set by ReadyNas when not recieving automatically ip by DHCP
I'm a bit stuck here and hope someone can help.
Regards
Tony Pedersen
Turbogutten wrote:I'm a bit stuck here and hope someone can help.
The workaround would be to assign the duo a static address. A trickier one is to use 192.168.168.x as the LAN subnet, and reserve 192.168.168.168 to the NAS. Then a DHCP failure would still end up with the NAS using the same IP address. However, it is better to just use DHCP, so hopefully you can get it to work.
In addition to checking the cabling, you should also
- try a different switch port in the router
- try putting a switch between the NAS and the router
- look for a setting in the router to turn off the "green network" feature for ethernet
You could also try removing/reinserting the ethernet cable after the NAS is booted, just to see if the DHCP issue occurs only when the NAS is booting.
- TurboguttenAspirant
UPDATE
I was not able to fix my problem trying all sugestions from Asus support, so I returned the Asus router and bought a new Netgear X6S router instead. And now I am really fustrated, because I have exactly the same problem using the new Netgear router.
When conecting through the router, the Nic Light is on both the router and the NAS, indicating that they are conected, but the NAS is not detected by the RaidAr and do not show up at the routers network map .
When conecting directly through my laptops Lan port RaidAr detects the NAS, and I can browse the NAS and and also log into and use the Frontwiev admin page.
The NAS network interface IPv4 is set up to "use value from a DHCP server", but even so it seems like it is not obtaining ip adress from the router, or if it is it will not connect to the router/network.
I also just tried a OS reinstall (but I am not quite sure if that went through since RAIDiator firmware is still 4.1.16 after reinstall).
What could possibly be wrong here ? Everything was working just fine before my old Netgear X4 router died.
Anyone ? ?
It would be the same, since every time you install firmware the NAS also updates it's flash.
The OS reinstall will reset the admin password to netgear1, so watch out for that.
Are you seeing negotiation of a gigabit network?
If you are, I think the next step is to set a static IP address in the NAS, and see if that works when you connect the NAS to the router.
- Marc_VNETGEAR Employee Retired
Welcome to the Community!
Have you checked if there's any issue with the cable? or if the NIC LED indicator lights up? Do other devices get DHCP address from the router?
You may want to check with Asus' Support regarding settings.
Regards
- Retired_Member
Hi Turbogutten
If your old router was and new router is not using the same ip address (ipv4, I assume), your nas is still in love with it's retired old buddy and is looking for the the router under that old ip address.
so, please check in the network configuration of the nas, whether the correct ip address of the new router is specified.
happy fixing and kind regards
